dougrainer
Jun 20, 2020Nomad
enblethen wrote:
Did you check the ground where it attaches to the frame?
I did not see what type of rig, make and model?
Bingo. The OEM's run the ground from the battery to a Frame ground. Then the Power Converter/12 volt fuse panel and ground lug for the interior dc appliances then run a large ground down to the frame. NOT the same connection on the frame. A quick correct fix would be to just run a 8 gauge WHITE wire from a secure frame connection to the interior ground buss bar. Don't spend time looking for the loose connection especially if you have a enclosed underbelly. Make sure the Battery ground to the frame is GOOD. Doug
