D_MAX
Jun 22, 2020Explorer
Gjac wrote:
Another thing to check is the set screws that hold your 12v wires in place on either side of the 12 v fuses a loose screw could cause an intermittent problem.
Thank you, I’ll definitely check them.
Because this is intermittent and currently not a problem, it’s going to be more frustrating as I may not be able to actually ID the fix unless it’s super obvious. My weekend ahead will be the joy of going over all connections and insuring I have good grounds.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
