garmp
May 08, 2022Explorer II
Power drain
We are not full timers at all. Our coach will sit for a month or so, especially in the winter months. We do start it and check things periodically. Without starting & running frequently it seems that ...
garmp wrote:
That's what I did. I put a knife type switch on the negative terminal and the issue has stopped. What had prompted the question is that I had the coach at the repair shop to have the catalytic converted replaced, third one stolen, and this one had a CatClamp installed and the part is on back order. So I had to remind them about the cut off switch to save from buying another battery. Just a minor inconvenience unless you forget to tell some one.
Thanks for all the replies.
