mchero's avatar
mchero
Power Gear Parts
Looks like one of my spur gears on my full slide went south. Need to replace because a couple gear teeth broke. I have all the part numbers BUT where will I be able to purchase w/o going thru a dealer or distributer? Is it possible?
Gear 250-0005
Set screw 15-1412 (2)
521336 Woodruff Key
Thanks
  • JoeH's avatar
    JoeH
    Explorer III
    Good Luck-- when I had a Power gear slideout gearbox break a couple teeth, they told me I had to buy an entire gearbox/motor assembly. I was able to find used parts to get it back together and avoided the $600 + charge for a new motor. What I found in my setup was the potmetal that held the bushings the gear shafts rode in had elongated, causing slop which eventually broke the teeth on the gear. I fixed that, put in the new/used replacement gear and had no problems afterwards
  • I see PPL motorhomes listed as a distributor. I'll go check out PPL Parts.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
