DanMar's avatar
DanMar
Power Gear Slide Control Relay location
We have a 2000 Holiday Rambler Endeavor 40 PBD with Power Gear slides. Question is...can anyone please advise where I can locate the slide control relay box for the front slide? I am told that the relay may be my problem, but I can't locate it!!! Any help is appreciated..thank you
  • Ivylog's avatar
    Ivylog
    Explorer III
    Should have added that Monaco will want the last six numbers of your vin to be able to help better.
  • Thanks Ivylog..the only noise from pushing on the teter toter switch (in & out), is a clicking at the Power Gear motor. I'll look around/underneath the front step in the morning. Also, I'll try calling Monaco on Monday morning. Appreciate your help!!
  • Ivylog's avatar
    Ivylog
    Explorer III
    Usually the relays that control your slides are on the hydraulic power pack often near the steps. Where is the noise of the motor running at? You can also call Monaco ((877) 466-6226)
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
