wa8yxm
Jul 21, 2019Explorer III
3 tons wrote:
I have a Powergear slide in a truck camper (two geared rails but only one motor), but try as I might, I’ve been unable to find any kind of ‘controller device’ between the slide in & out switch and the slide motor...Kinda weird (??)....
I found it on mine but had to "Sniff it out" bloodhound style
On my Damon INtruder the slide out controls are in the hall roughly the Middle of the RV (Between front and rear rooms)
The slide out motor is the main (Front Room) slide so it's a bit in front of that
The controller was on the ceiling of a basement compartment as far towards the front of the RV as was possible. the next thing forward is a wheel well. WHY I do not know (Hide the box contest???)
I found it by.> Well it failed. so a tech cut the wires and I built a home made bypass controller (no current limiter)
I hooked a Harbor Freight cable tracker to the cut ends since I knew they had no power on 'em (Checked first) and bleedl bleedled my way to enlightenment (Followed the line of greatest sound when the bundle branches well one way had sound the othe silent)
Now the following link is the one I used. found one like it 10 bucks cheaper on Amazon but.. This is the exact one I used. Walked in and walked out with it (Can't do that on A)
Cable Tracker/finder at HF
I Have a major repair than another major repair then that's next.
(And a couple minor ones as well).
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
