Songbirds
May 14, 2019Explorer
question & Answer may not help you. BUT, Do you have more than one slideout? I ask this because I had a stuck slide in the out position. Removing one off one control and putting it onto another and it worked for me. Say slide one not working at the motor. But Slide 2, is working just fine. Remove the control of 2 and put onto 1. Then check and see if doing that works for you, as it may be just stuck as mine was.
