Diesel_Camper
Sep 05, 2016Explorer
It sounds like a loose connection, usually this type of problem is caused by a loose neutral (white) wire, but not always. The outlets in my RV use a wedge and clamp type of connection for the wires instead of screw terminals which means they could wiggle loose. These type of connections are used with unstripped wire, and the wire is pushed into a sharp wedge that pierces the insulation and makes the electrical contact. I would suspect the problem is on the back of one of your outlets, but it wouldn't hurt to tighten everything up inside your panel if you're comfortable working with electrical panels.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
