westend
Sep 05, 2016Explorer
Oh one last thing - I have a Keystone so the inverter and all the 120-volt outlets are tied together, not sure if that matters.
This typically means you have a transfer switch somewhere in the 120V system. If the transfer switch only powers the problem receptacles, it would be the first place I would look.
Transfer switch duties may be handled by the inverter. Listing the inverter brand and model will help with discerning if that is the case.
Diagnosing the issue with a hand-held meter is the most accurate process.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
