23hotrodr
Sep 07, 2016Explorer
Unfortunately, there probably isn't a quick diagnosing tool. You could use one of the inexpensive plugin testers with 3 lights on it to go around and test for power. This would work best if you have the wiring diagram so you can see the route from one receptacle to the next.
But most likely, you just need to systematically go around the RV and tighten all electrical connections.
Good luck
Good luck
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
