fj12ryder wrote:
One more question about these power packs: is there any way to tell, short of actual usage, to see whether they would do the trick, i.e. jumpstart a small engine?
I know you can use a load tester to check a battery, is there anything of that sort to check one of these power packs? Without destroying its integrity?
fj, if I were you, I'd buy the one from Costco (assuming you're a member) and try it out.  Take it back if it won't do the job.  IMO, all the decent ones will start a small engine no problem based on the case I've seen and referred to earlier.
