kg1d_dxExplorerJun 15, 2018Power ProblumI made up an extension cord for my rv. It is a 50 amp system, the problem is when I put power to it one leg is 115 volts and the other is 150 volts. At the outlet the voltages are 115 each leg, plug ...Show More
donn0128Explorer IIJun 15, 2018Check your connections. I would be willing to bet you have a cat whisker jumping between two terminals.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentNo power on outside GFCI outletAdding power outlets in slide with no wiringNewbie power question12 Volt Power IssueNo DC Power
