ryankenn's avatar
ryankenn
Power Sag/Current Issues at Seasonal Site
We are in our first year at a seasonal site we think we will be staying at long term. Everything is great, but the power. We only have a small Jayco 16XRB but even its 8K Btu AC and fridge prove challenging.
I haven't had my meter on it yet but you can tell by the sounds of the fans or AC that either the voltage droops badly or the run on the 12 wire from the looks of it is so long current isn't being delivered as fast as its demanded. Depending on neighboring usage fans will start slow and ramp up.
I am looking for ideas on how to combat this? I have setup a solar array at home before, but I don't know what to search for in terms of a device like an MPPT controller, but instead of the panels, that input is line. I would like a bank of batteries to be controlled and charged by the pole 120V (or sagged level its at) and the controller to supplement the supply using the batteries and an inverter so the trailer has steady voltage and good current delivery.
I had hoped a device existed but in searching it may be more practical to just have the site run a charging system that keeps a bank of batteries full and I draw from an inverter.
Thoughts or experience here would be great. The Norcold has already had one control fault leaving us with spoiled food and the neighbour has had some HW boards and the in trailer 12V inverter board fold because of the same issues and I want to avoid this.
Thanks!
Ryan
  • In addition to Valhallah's comment, solar to charge the batteries, allowing you to turn the converter off can provide some help.
    Otherwise, the Autoformer.
  • Some careful research MIGHT locate an inverter that will ADD power to your circuits ! Then a good solar and battery setup would be another solution.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I kept voltmeters pluggedin
    I also used a Hughes Autoformer
    Now with the autoformer there is a trade off. especially on a 30 amp site
    Your RV does not eat volts or amps. but rather watts. (Volts times amps)
    So if the voltage out the post is say 100 and the hughes kicks it up to 115 Well your maximum wattage goes from 3600 (30 amps times 120 volts) to 3000 (30 amps times 100 volts) before the park breaker trips. But.. everything works provided you keep that in mind.
    One thing I did was swap out the water heater element. instead of a 1500 watt at 120 volt I put in a 1500 watt 250 volt (375 watts at 120 volt) element, Took a bit longer (4x) to heat water.. But fewer trips to the pedestal to reset the @#%$@## Breaker.
  • It's a common problem, particularly at older parks.
    1) Get a voltage meter. No point fixing something that isn't the problem. I suggest getting one that plugs into an outlet full time and put it where you can see it frequently.
    2) Solar is a separate subject and largely irrelevant to if your park has low voltage.
    Assuming you do have low voltage, there are some options:
    - Pick up an Autoformer (google it). These devices will boost voltage by 10%. They aren't a cure all (if the pedestal is at 80v...that's still going to leave the air/con seeing only 88v) but it will avoid a lot of marginal voltage issues.
    - Switch as much as you can over to propane. So the fridge and particularly the water heater. The more amps you are drawing, the more it pulls the voltage down. If it's only one hot afternoon, you could turn off the battery charger but then you have to remember to turn it back on later.
    - The final solution is picking up a generator. I would suggest looking for one at least in the 3000w range. You can make some smaller ones sometimes work but it's really marginal. Some will say the campground won't allow it but we've had good luck telling them to provide the 120v power we contracted for...and they have always backed down.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
