MrWizard
Aug 26, 2016Moderator
Simply put... It's illegal.. Against every electrical code NEC, state, and local municipal, And dangerous
Also
Any shore voltage so low that you can't start the A/C, will damage the compressor when you run it after disconnecting the generator
We are all aware of campgrounds with low voltage that are able to start the a/c, then burned out running A/c units
Voltage so low that you can't even start the a/c , is fool hardy to even run it, much less sync a generator to it
Run the a/c from the Honda, or try using an auto transformer to boost voltage
Switch Every thing you can to lp
Fridge will not stay cold on low voltage power
Also
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
