Gdetrailer
Nov 08, 2015Explorer III
a. serrano wrote:
I have a diesel Power Tech Generator that will not start. Can you tell me what may be the problem?
No.
No matter how much I try I just can't get enough info out of "will not start"..
For an diesel engine you need three things.. Fuel, air, compression.
Do you have fuel?
So does it crank (rotate, turn over, move) when you try to start?
Does it have glow plugs, are they working?
And so on..
Fair chance you have a fuel problem if engine turns over with no start.. Try a new fuel filter if that is the case..
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
