wolfe10
Jun 07, 2018Explorer
EnzoColorado wrote:
My trailer's AC won't run unless it's plugged into an external 30 amp power source like full service campgrounds. At home I use an adapter to plug into my house's outdoor outlet, which will run everything but the AC. I think the house circuit is 15 amp. Is it possible to find a Y adapter to plug in two house extension cords (from two different circuit) into the trailer to run the AC?
Please tell us what happens when everything except the roof A/C is off and you try to run it on your home 120 VDC/15 amp outlet.
CRITICALLY-- WHAT IS THE VOLTAGE as measured at any outlet in the RV?
As stated, the roof air WILL run on a properly wired (large enough gauge wire that you don't have a large voltage drop)15 amp power source.
