Old-Biscuit
Nov 30, 2013Explorer III
Generator running..........does it load up?
Need to check whether or not you have AC power to rig......got a volt meter?
Are other 110V AC equipment working.....A/C Unit works, fridge works on AC, microwave works, water heater works on AC, other outlets have power etc.
IF NO then gen. power is not getting to AC Dist. Panel.....transfer switch bad
IF Yes then problem is with that outlet (coffee pot plugged into) or with the AC circuit breaker.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 15, 2026
