live4thedash
Dec 02, 2013Explorer
Hi ~ Okay so I did some more checking. When I pulled the cover on the generator (marquis gold 5500 onan) and the 30 amp switched was flipped so I set it back. The switch above that was okay. I then started the generator, set the GFI in the bathroom and I was able to turn on the TV, the micro was on, etc. However when I plugged the coffee maker into the outlets on the counter did not work. I then got a house fan and plugged that in and it did not work. I then took the same fan and plugged it into the bedroom outlets and it worked. so it looks like the the outlets in the front of the coach do not work. Never ending right??? :)
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
