bukzin
Dec 14, 2013Explorer
live4thedash wrote:
Found it~ back up and working. I'm not sure why the generator 30 amp would have triggered as I didn't have anything plugged in and things were not running other than my blowers for the furnace to warm the MH up. Maybe because it was so cold and I hadn't used it in a while? Not sure...thanks everyone. Now I know about that breaker on generator too! Never ending...guess they call it learning!
So, in the end, did you have both a main breaker on the Onan
and a GFI tripped.
You might want to write down the location of each of these breakers
(Gen-set, inverter, GFI's, etc.)
I'd copy that little note and put it in both my owners manual and in your main circuit
panel box.
Someone (likely you) will be glad you did!
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
