ktmrfs
Oct 22, 2021Explorer III
Gjac wrote:
I would disconnect the neg battery terminal and set your muti meter to 10 amps with one lead on the post and one lead on the cable. This will tell you what your parasitic draw is. If over a couple of amps something is left on . If you do this simple test first and post what your draw is you will solve your problem. As a data point my parasitic draw on my chassis battery is .4amps. If less than 1 amp I would check the cells in your battery.
couple of amps is WAY to high. if everything is off, draw should be on the order of 0.01A or less. Even 0.4A is going to discharge a battery bank faster than you want. That's about 10Ah/day
