Gjac
Oct 23, 2021Explorer III
ktmrfs wrote:As I said in my post if you have a couple of amps draw something is left on. However I misplaced a decimal on my parasitic draw, it should read .04 amps or 40 milliamps. On a newer MH with radio, satellite ,GPS systems, Wifi and other electrical stuff the draw will be higher. For OP's batteries to go dead in 10 days something is left on or batteries are bad. If after you check the draw and find it more than an amp or two you can then go to your 12v fuse box and start pulling fuses one at a time to see which one reduces the draw.Gjac wrote:
I would disconnect the neg battery terminal and set your muti meter to 10 amps with one lead on the post and one lead on the cable. This will tell you what your parasitic draw is. If over a couple of amps something is left on . If you do this simple test first and post what your draw is you will solve your problem. As a data point my parasitic draw on my chassis battery is .4amps. If less than 1 amp I would check the cells in your battery.
couple of amps is WAY to high. if everything is off, draw should be on the order of 0.01A or less. Even 0.4A is going to discharge a battery bank faster than you want. That's about 10Ah/day
