DrewE
Dec 04, 2017Explorer III
As Mex said, assuming it's a 12V battery, any 12V battery will work fine. The amperage is determined by the voltage and the impedance of the starter, not by the size of the battery (well, assuming the battery isn't so small that the voltage sags excessively while cranking).
You probably can find a replacement battery of the same size elsewhere, though, even if it's a different brand. Maybe something like this would do the trick.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
