SidecarFlip
Dec 05, 2017Explorer III
What is to 'service' anyway? Oil change, clean the foam air filter, replace the plug every 5 years run descent gas with stabilizer and you are good to go. Even a valve adjustment is cake. The valve cover is 'O' ringed and the clearances are in your owners manual and it has screw type adjusters. Box wrench and flat blade screwdriver and 5 minutes.
I should be in small engine repair and service, I'd make a killing,
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
