Hybridhunter
Sep 03, 2013Explorer
westend wrote:
Thanks for posting to show that a 6K AC can be run off the inverter and batteries.
I think you may be mistaken on the output of the alternator. More common are 100-130 amp alternators in Ford pickups. I may be behind the curve, though, as I don't have much experience with newer Ford's.
Bottom line is that it's working for 'ya and that is the most important.
Ford electrical linky - 220 amps
I looked into it, it is a 220amp alternator. Around 150 amps available at idle, minus whatever the truck needs to run, I estimate 40 - 50 amps for my particular truck, but I will clamp on an ampmeter at some point to see. Based on voltage drop calculations, I was pulling around 70 amps to run the AC, and later, about 45 - 50 amps initially to charge the batteries. Startup voltage when it senses a load a 14.3v at the vehicle bateery terminals, after an hour 14.1, 2nd hour it stayed around 13.9v RPM had no effect, so it was regulated, not maxed out.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
