McZippie
Sep 03, 2013Explorer
Elev8orman wrote:
This is something that's been kicking around in my head. I've been researching alternators and i've seen 2 that have an output of 370 amps at 1200 rpm. If my math is correct then that is 4440 watts @ 12 vdc. Putting this in an inverter should give me 37 amps @ 120 vac.
I think there will be a loss of maybe 10% but I think I could power my trailer including A/C.
Thoughts?
Yes this can be done, with a special Bus high output alternator.
The inverter would need to be mounted close to alternator/ batteries and 120 volt wire to trailer.
Our rig is set up to do this (clicky below) but haven't used it because we don't have a travel trailer. I'm currently having a custom TT trailer built that will be able to power the TT's 120 volt AC from the tow vehicle alternator. The TT will have a generator also.
The tow vehicle's 120 volt system may be used to pre cool the TT while driving.
All in all putting these unique RV systems together from the best of boating, bus, semi-truck and European RV tech in a compact touring rig is my hobby. It gets real expensive and as many have already posted, a stand alone generator that is set-up to run while under tow makes the most sense.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
