MEXICOWANDERER's avatar
Sep 11, 2015
Precious Honorable Instruction Manual
Yeah this is a list. I've seen some Deusey's, but here's one I came across while shopping for honorable latching relay.
1 Channel Latching Relay Module 12V
Description:
1. Power supply to meet the scope , DC 12V;
2. The power required by the by -line diagram , is not reversed , although the protection circuit , but not for a long time reversed ;
3. Product regulator slight fever is a normal phenomenon , long working hours have a normal relay heat phenomena are normal ;
4. Relay load power to give leave some margin should avoid high-power ( about 2000W) and long working environment , there will be some impact on the life of the product .
Features :
1. Double panel design PCB;
2. Chips made ??using stable and reliable control , stable and reliable performance , strong anti-interference , not false triggering , performance is superior than the CD4013 ;
3. Regulator has the power to provide adequate and stable voltage , and have enough vents to ensure stable and reliable product for a long time to work ;
4. With anti- reverse protection diode power , reverse power for a short time without any damage to the product ;
5. Use SONGLE genuine relay control load in 250V 10A ( AC ) and 30V 10A ( DC ) under load can withstand ;
6. Has a touch switch as product testing , stability testing of products directly ;
7. Can also trigger an external trigger switch , the products have a connection with a good seat and lead , more convenient to use ;
8. Triggering sensor module can also be used to do other triggers , are valid as long as the trigger is low , there are more functional expansion;
Parameters :
Supply Voltage :12V (DC) supply current : more than 100mA
Load : 250V 10A (AC) or 30V 10A (DC)
Life: 1 million times
Usage:
Press the trigger button , the relay is locked , press again , the relay off , you can also add the trigger switch , and the use of low-level trigger .
Control appliances , home of various lighting control, factory equipment control , current control for a variety of small high-voltage power control products .
Packing list:
1*1 Channel Self-locking Relay Module 12V
1* Trigger Line
Pleased to add your own!
  • I figure the language fiasco is heavily dependent on "Saving Face". Lin told me a few years ago a company who had to reach outside it's corporate structure for any phase or part of product development was sneered at. When I was doing some lightweight research at U.C. Berkeley in the late 90's I discovered the campus to be filled with (thousands) of Chinese Nationals. Those whom I spoke with managed English quite well.
  • Bought a large and very expensive piece of processing equipment many years ago that had a wet and Dry section. The Safety label read " These Parts be Hotting for a Warm Wind of Drying!"
    We laughed about that for Years!
  • My early 70s Datsun owners manual warned to drive safe in the rain; avoid the traction devil. Or something close to that.
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
