BrianinMichigan's avatar
Feb 28, 2016
Prelube pump
Does anyone have one? And how do you hook one into a gas engine? I got thinking as long as my 454 sets over the winter it would be a good Idea to have one for those long setting starts.
  • An quality aftermarket camshaft with an exceptionally mild grind with roller cam followers will end the flat-cam syndrome faster than you can say "Harmonic Balancer". Something like Bruce Crower's works. Several brands of engines had the sloppiest cam timing a person can conceive of and while 2 degrees of advance or ****** won't flatten the lobes sloppy heat treating will. The 454 series engine, along with Ford's 460 are members of the sloppy timing -other reality- cam lobe profile club. The old FE class Fords, 331-360-390 engines were charter members, the 406 and 427 engines were different animals, but Ford returned to their evil ways with the 428. MoPar ain't exempt. The L3 440 cylinder head valve seats (induction hardened) might have had department supervision by a Borneo cannibal.
    Keep in mind unless your rig is stored where there is no 120vac power, your search for a suitable pump is not limited to 12-volts. An 80-PSI bypass (relief) valve is recommended for larger capacity units.
  • It sets under a 24 x 36' pole structure I have 120v plugged in all of the time. I'm still waiting to hear from the company that uses a pump to circulate
Having RV issues? Connect with others who have been in your shoes.24,191 PostsLatest Activity: Jan 19, 2025
