dougrainer
Dec 17, 2015Nomad
bbaker2001 wrote:
dometic 2852
the refrigerator will get to 38-40, but the freezer will not go lower than 20. if the thermistor is set to 38, how can freezer get to 0.
The Freezer in a RV refer is NOT controlled by any tstat. The freezer in a RV refer should ALWAYS be below 10 degrees and most get to 0 to 4 degrees. The Cooling unit system is designed to transmit full COLD to the freezer FIRST and then down to the refer. That design gets the freezer to below 10 degrees regardless of the tstat setting. ALWAYS has been this way. Also, the TEMP of the Evap fins in the lower section will be 10 degrees COLDER than the actual temp. So, if the interior temp is 38 degrees the fin temp is 28 degrees. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
