profdant139's avatar
profdant139
Explorer II
Jun 11, 2017
Priming Honda 2000 after draining carb: when is it primed?
So I store the generator with the carb drained. The next time I have to start the generator, I have to pull the rope slowly a number of times until the carb is primed.
Is there a way to know when enough is enough? How do I know when to switch from long slow priming pulls to fast hard starting pulls? Right now, I do it by trial and error, which is inefficient.
And yes, I have researched this issue and have come up empty.
Thanks in advance for your advice!
  • Snowman9000 wrote:
    romore wrote:
    You can open the drain valve until clear fresh gas comes out, close it then pull normally.
    Are you sure? It has a fuel pump. I would think the only way is to pull and pull. Other than to pressurize the tank, or to squirt a little some into the carb inlet.
    I don't think so either. I put the engine switch in the ON position, leave the fuel cap vent lever in the OFF position, and shake or rock the gen set side to side vigorously for about 10 seconds. This rocking causes the gas to expand and push itself into the carburetor. Now turn the fuel cap vent lever to the ON positions, set the CHOKE to FULL ON and PULL once; Wait 10 seconds, PULL again. Mine usually starts. If not wait another 10 seconds and PULL again.
    LeRoy
    Edit: I noted that the engine switch needs to be in the ON position while shaking the gen set.
    I know because I can hear it try to start even on a slow pull. Then I fast pull.
  • No, once you empty the bowl you have to pull the starter cord until the pump fills the bowl again. This seems to take 12~18 pulls. It may self fill if the pump stops in just the right place but I doubt it.
    Dont bother trying to "prime it". Just turn everything on and pull until it starts.
  • You can open the drain valve until clear fresh gas comes out, close it then pull normally.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
