ken_white
Jul 15, 2014Explorer
cannesdo wrote:
Here's a photo of that panel that's in the upper left of the schematic.
http://imagehost.vendio.com/a/2918824/view/panel.jpg
I looked all over and there is nothing like a buss board aside from one that seems to be comprised entirely of ground wires. There is just nothing else in that space (or anywhere in the basement that I can see. Just the big fuse, the inverter/converter combo unit and this panel. Can someone tell me how to check the various points on this panel with my multi-meter? Is one of those little boxes likely bad? What are those little boxes? The black wire at the top goes out to the big 300/150A fuse.
Thanks so much....
Your picture shows a positive bus connected to numerous automatic resettable breakers.
Measure the voltage across each pair of terminals.
If there is a voltage across any pair, then its open and either there is an issue down stream (breaker tripped) or the breaker is bad.
No voltage across the terminals means the breaker is not tripped.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
