cannesdo
Jul 15, 2014Explorer
Chris Bryant wrote:
Just to make sure- the schematic shows an "Interior power kill switch", which is between the breaker we have identified, and the inside fuse panel. You have checked it, I assume?
I'll add that for troubleshooting 12 volt power problems like this, a 12 volt test light is far better than a meter, and easier to use. Just clip the wire to a good ground, and probe away.
Thanks for the response. I don't know where the kill switch is. There's nothing on the main panel where the fuse panel is that looks like that and nothing that I can see in the wiring between the panel I've been testing and the fuse panel. But the schematic does show it's there -- I googled it. Don't see anything like that in there. Maybe it's directly behind the fuse panel? Should I pull that?
I was using a fuse checker on these and everyone told me to use a multi-meter instead. They all light up with the fuse checker, like my fuses in the fuse panel used to, before this happened. Now none of them do.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
