ken_white
Jul 15, 2014Explorer
cannesdo wrote:
So it might be the AC breaker, even though turning that off and back on again doesn't do anything? This wouldn't explain why the slides and the 12v lights don't work. ?
Actually, I was wrong.
Chris stated the DCV cutoff switch could be the problem and he is probably correct - I just looked at the schematic. I am not sure where it is located in your camper, but it will disconnect 12 VDC power to the loads you are concerned with.
Trace the Black, 8 AWG wire on the silver post back to the switch connection.
The switch is located between the breaker connection and fuse panel.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
