dougrainer
Nov 21, 2015Nomad
1. If the fan runs there are no fuses to check
2. IF it does NOT light, it should shut the fan OFF within 5 minutes. Does it shut the fan OFF?
3. Since it is NEW, odds are the Hi limit switch has opened. If you bang the exhaust vents(after removing outside access door) for a few seconds that will sometimes close the hi limit switch. BUT, if this is the case, you need it replaced as it is a weak switch. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
