nomad297
Mar 26, 2014Explorer
Old-Biscuit wrote:mikeh449 wrote:
did you open pressure relief when you put water in the heater to burp it
Why do you 'burb' it thru PRV?
Open a faucet to expel air in system.
WH tank is designed to have an air pocket in top of tank so that the air can be compressed when the water is heated (water can't be compressed----pressure increases---PRV leaks)
Ok now...let's keep our plumbing acronyms straight. A PRV is a pressure regulating valve. A T&P is a temperature and pressure relief valve.
Bruce
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 12, 2026
