Andonso
May 12, 2018Explorer
I tried to find some markings using my reading glasses.
I suppose I can jumper it using another fast acting 15 amp fuse before desoldering.
Once removed I'll inspect it further using a magnifying glass.
It's ~35mm long. Most longer fuses I've see are 20mm long. Searching so far hasn't produce any 6mm x 35mm fuses. I think I remember a fuse while searching that's 6mm x 32mm.
But there must be some sort of replacement fuse somewhere and length may be important for a replacement.
I also inspected the PCB for markings but none showed anything about fuses and amperage
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
