SoundGuy
May 13, 2018Explorer
Andonso wrote:
The battery that was previously low on electrolyte was low again so I removed it and now have only two RV batteries temporarily connected to an Xantrex 10 amp charger which brought the two RV batteries back up to ~12 volts.
Elsewhere you said - "The battery loosing electrolytes is dated 01/06 while the other two 01/07"
... so along with the fact you weren't able to restore these batteries to any more than ~ 12 volts that would indicate these 10+ yr old batteries are pooched, regardless of whether your PD converter works properly or not.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
