Andonso
May 13, 2018Explorer
MEXICOWANDERER wrote:
It is marked on one of the metal end caps. Which may be facing the PC board. Good luck to you.
Yes after removing the fuse I was able to make out 20 AMP 250 VAC from the end cap. However this doesn't provide you with the fuse type.
This fuse has metal end caps with additional metal caps that hold the pigtails and obscure the part number.
Similar to
I was able to vaguely make out ABE which is I believe is the same as an ABC series.
These fuses I don't think come from the factory with pigtails. This is importan to determine a fuse type.
Pigtails for board installation are usually installed after the fuse has been manufactured.
There are adapters that will convert a fuse to have pigtails.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
