Andonso
May 16, 2018Explorer
wnjj wrote:
Andonso, also try disconnecting the red and black wire from the rectifier and check ohms between them (with the power off of course ;))
00.1 - 00.2 ohms
I'm finding continuity between the oppoisit side of hot size of the fuse (connected to AC black hot) and the lower left white wire on the rectifier.
Also continuity exists between the upper right white wire and the white (neutral) AC input.
The red wire on the rectifier has some sort of coninuit to the three large capaciters.
I will test later by pulling the red and black wires as I'm down to my last fuse.
After removing the bridge rectifier I found a part number GBPC2504
found a GBPC2504 on Digikey
gbpc2504 rectifier
And other brands
https://www.digikey.com/product-detail/en/diodes-incorporated/GBPC2504/GBPC2504DI-ND/248703
ebay
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
