Rbertalotto
Nov 25, 2016Explorer
The circuit board does indeed have a Charge Wizard button. But when the cover for the WFCO is in place, you can't reach the button and my charger is down near the floor and you can't see the LED indicator light. The $10 Wizard Pendant is the way to go.
I've been trying to find info on the two pins marker "WET" and "GEL". Seems like there should be some type of jumper connecting them for one type of battery or the other.
Tried to call PD but they are on holiday until Monday.
Once it stops raining I'm going to turn everything on in the trailer to run the batteries right down and then use my clamp AMP meter to see what I'm getting to the batteries. I have about 14' of #4 wire running from the charger to the batteries. Everything runs through a Bogart Tri-Metric so I should be able to monitor performance quite well.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
