ktmrfs
Feb 21, 2018Explorer III
Old-Biscuit wrote:
Per Manual
ByPass |
This switch is located on the remote display and allows the user to bypass the EMS in the event of failure, thus allowing AC power into the RV.
This does not disable the surge protection portion of the EMS; however, all other features are disabled
So YES.....AC Power will continue to fed RV regardless of voltage (HIGH or LOW)
well, yes, that is what the manual say but that is NOT what the unit will do. I have watched mine drop out around 100V even in the off position. looking at the circuit, it looks like they use a relay with a fixed low voltage dropout. so even with it off it can drop out. it may drop out at a lower voltage than when on, but it will drop out if the voltage goes low enough.
so, all you can do is turn in off and watch and see if it still drops out or not.
