SoundGuy
Feb 22, 2018Explorer
DD716TED wrote:
Nothing in the trailer is on except a small 350 watt heater and the power distribution/battery maintainer panel.
If the trailer is in storage why power the trailer at all? :h Just disconnect the trailer from power entirely and disconnect the battery, either with a disconnect switch or by removing the cable to the negative terminal. Once this wiring issue is resolved you can then resume powering the trailer without concern for nuisance trips. FWIW, the latest versions of TRC Surge Guard #34830 & #34850 which so many here on the forums malign include a low/high voltage trip time delay of 8" to 10" which is intended to help avoid the chances of nuisance trips when voltage is hovering around the low/high voltage trip thresholds. The Progressive EMS don't have this feature and is the reason you're experiencing so many nuisance trips. :M
