CA_Traveler
Feb 22, 2018Explorer III
Never ever leave a RV connected to shore power when you know they are/may be working on the system regardless of what protective devices you have. Unplug and stow the cord so someone can't plug it back in and disconnect the battery. Not doing this exposes you to high/low voltage and/or faulty wiring.
After the changes are completed check the plug very carefully for voltage, polarity, etc. Recommend you then plug in a heater for load and recheck.
Yes most of the time it will be OK. But there are posts about it NOT being OK.
