mdamerell
Dec 10, 2014Explorer
Specularius wrote:
Mdamerell, I read that all over the manual and the interwebs. No where does it say how to activate it or when it is activated.
OK, I must be a little confused over what you are asking. Here is what I know and I hope it helps you out.
I plug in my 5er to the post and turn the post breaker on. After about 30 seconds (I think) the unit turns power on to my 5er. I watch for the clock to come on the microwave. I check the display to see what kind of power/voltages I have display. I turn on my water heater etc... shut the cabinet door and go enjoy my self. Since I did not want to see the numbers displaying all the time I had it installed inside my coat closet with all my other tank gages, slide and yawning controls. There is a switch on the display to turn it off and there is a manual override inside the actual unit. I know about the internal switch since the shop installed it backwards the 1st time and when you pushed it, it allowed power to the trailer, but once power is disconnected, the switch will automatically reset.
Basically if you can read the leg voltages the unit is working. If there is a "E" code or error cord you have an issue. If the display is off, so is the protection. I believe they think it's so simple you don't have to write it out, although they seem to say it round about.
I know it works cause it's saved me a couple of times. One time the utility line crew in CT screwed up and caused power issues in the campground and surrounding area. The second time a power post lost its ground? in OH (something about ground water and bad insulation).
I hope that helps.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
