BFL13
Dec 17, 2017Explorer II
Propane Amount Question
I still don't understand my propane situation. Any help appreciated.
I have a "76 lb tank" which I take to be "full" at 80% or 61 lbs. I am used to having two "30 lb" bottles, but when they get filled I am charged for typically 30 lbs, and they are only filled to 80% as well?
So it seems my "76 lb tank" is about the same as two 30s in real life?
As an example my first time to refill the tank it was showing about half full, and they put in 26 litres to fill it. I got charged by the litre for the tank instead of by the pound as with cylinders.
My Manchester hand- out says 4.24 lbs/gal (US gal no doubt) and that would be about 3.8 litres/gallon? so a 30 lb cylinder would be about 27 litres which is about what they put in my "76 lb" tank at about half full, so I am thinking all I have here is a sideways two 30 lbers same as I had in the 5er.
Is that about right? Or how do you figure propane amounts?
I also don't understand the "liquid propane" deal, where I had to go to a sort of gas pump that did propane to fill the tank instead of to the usual cylinder fill place. Don't cylinders get "liquid propane" too? But they charge by the pound to fill a cylinder, but by the litre to fill the tank.
