red31
Nov 22, 2017Explorer
wa8yxm wrote:
Thankfully the Excess flow valve did what it is designed to do and prevented just that.
The spring load shut off valve that works in conjunction with a thermal bushing in the ACME worked, designed to SHUT OFF if the thermal bushing melts from fire and prevent propane flow unless something is attached. Nothing to do with Excess flow feature.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
