red31
Nov 25, 2017Explorer
SaltiDawg wrote:
I do not believe that this is correct at all.
The proper way to "fill" has been by Net Weight. This has been true for decades. (20# on a "20 Pound Cylinder."
Filling by volume is allowed for DOT cylinders that are not under DOT jurisdiction (commerce), unless the state has adopted other rules, like the state of TX where DOT containers of less than 101 pounds LP-gas capacity, other than containers designed to be used on forklift or industrial trucks, shall be filled by weight only.
20 lbs can be more or less than 80% depending on temperature.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 29, 2026
