Davidlee64's avatar
Davidlee64
Propane Cylinder Fill: Error?
I recently took my 2 outdated 30# propane cylinders to exchange for current inspected and filled ones. I recently went to switch out one of the in use cylinders that showed empty. I pulled the empty, and put in the filled one. I hooked the pigtail to it and went to slowly turn it on. WTH! The valve was already open! I checked the other cylinder and found that one was open as well. Is this some kind of new way to exchange or fill cylinders that I am not aware of? I understand OPD valves should not release any propane unless there is something attached to it, but isn't that carrying it a bit too far? When I go to service company to refill, they don't leave them open. The exchange place is a different company.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 08, 2025
