In my new to me Motorhome, there is a quick-disconnect propane fitting in one of my bays, what type and where do I find a hose to connect this fitting to my Coleman grille in place of the small gas bo...
denk, it is simple to determine hig or low. Look at your tank, the first thing connected should be the regulator, if there is a "T" in between the tank and the regulator, it is high pressure, if there isn't it's low pressure. No need to trace the line, everything after the regulator is low.
