Almot
Dec 05, 2015Explorer III
Brass fittings on the regulator end are all different because regulators are different.
You don't need to have a changeover regulator. Get a single-tank regulator if it's cheaper - and if it's regulator that failed, not the hose.
Yes, you can open one tank at a time. Don't need a changeover regulator for that. Flip the hose from one tank to another.
Yes, when hooking up one tank at a time, you WILL know when one tank is empty :)... Then you flip the hose to another tank, takes all 2 minutes, and refill the empty one at your earliest convenience.
LaunchnRetrieve wrote:
While playing with the hose we noticed the regulator doesn't fully seal off the other side when the lever is flipped to one side or the other.
No problem, I only open one tank at a time.
I want to know when one of them has run out of gas, not be surprised when both run out and I don't have a back up.
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
