Filled left side propane before camping this past weekend, get to resort and smell gas . (Right tank half full) . Checked bottles with soapy water mix (no bubbles) Two stage reglator (main) with singl...
Did you spray the RED regulator..the hose/fittings on the left side cylinder?
That RED regulator is a 30# single stage regulator. Drops cylinder pressure down to 30# and then it goes across to other side and main 2 stage regulator. The hose that goes across....check it for leaks also
